Neil wrote:on the plus side its worth twice as much now
Restorationvanman wrote:Thats bad anyway to answer youre question about the back panel if you're not worried about "originality" then you can use a MK3 one (think that 4's and 5's are the same too) you will just have to alter (reduce the height) of the cut outs for the chassis as 4's and 5's have "taller" chassis rails ive seen a Mk1 with a Mk3 panel for definate
Mfd-18v wrote:What are they worth as a chassis cab? As it is?
