by Retrohowla » Fri Apr 04, 2014 12:54 pm
You need to remove the cam belt to remove the pump timing sprocket, mark the pump shaft in relation to the sprocket before removal (i cant recall if its splines or a keyway, better to mark it incase), also note, as the pump sprocket is adjustable, note the position of its adjustment and then mark it, now you can remove the pump sprocket, then you can remove the pump, do your seal and then you know where it all needs to go back to on reassembly
If you own a transit, learn to weld
