I took the motorhome out for a longish run yesterday. About half way down a busy five mile stretch of single carriage road with no pull ins the thing started spluttering and banging.I nursed it to the next turn off and within yards it spluttered to a halt. After a load of messing about I found the electronic ignition had gone up the spout.With the ignition on the coil was sparking at random with the points (the system still relies on them but needs no condensor) open or closed.I cleaned the points,then fitted a new set and even added a condensor but still the coil would fire randomly with the ignition turned on,the engine would fire but sound horrendous.
Finally I took the whole thing off and put it back to standard.
Electronics is a bit of a mystery but I cant see how a coil can spark with one end live and the other in effect disconnected. Anyone any ideas?.
