I was in the neighborough, 500m away, a military vehicle collector had some ford a, 5 of them.. in military colours and looks bigger than transit but same doors,windows...
is there some good parts on ford a? i had a mk3 -86 transit svo that had some transit serie a parts on it. gearbox and some undercarriage stuff but these monsters looks huge.
So does any parts fit on mk2 transit?
they seems rare, but are registered as a light truck here in norway so ive seen not so much only military and 1 camper for 10grand.
also i copy paste from wiki
The Ford A-series was built in the UK to fill the gap between the relatively small Transit of 3.5 metric tonnes GVW and the bigger 7-tonne D-series.
The "A" cab shared most components with the Transit and the most notable differences are the longer and wider wings, longer hood and a different grille. Unlike the Transit that had a face lift in 1977/1978 the "A" retained its profile for the entire period of production.
The A-series could be divided into two categories:
The smaller A04xx with 14-inch wheels, 6x170 mm bolt pattern, and four-cylinder engines.
The bigger A05xx / A06xx with 16-inch wheels, 6×205 mm bolt pattern, stronger frame and six-cylinder engines.
Four different engines were offered: a 2.4l 4-cylinder diesel. A 3.54l 6-cylinder diesel, actually a 2.4 with 2 more cylinders, a 2l V4 petrol and a 3l V6 petrol. Three transmissions were offered:
Ford 4-speed 4-310 synchro only on 2-3-4, Turner 4 spd T4-150 1-2-3-4 synchro, and the ZF 5 spd S5-24/3 1-2-3-4-5 synchro offered as a high capacity unit.
3 driving axles were offered: The versions with 14-inch wheels had a slightly modified 50 series axle (Ford type 24) similar to the Transit. Ratios 4.625 and 5.125 Single 16 in wheel models had a Salisbury Engineering 8HA/Dana 60 (Ford type 27). Ratios 4.88 to 6.17. Dual 16 in wheel models had a Salisbury Engineering 10HA/Dana 70HD (Ford type 42). Ratios 4.88 to 7.17. Four wheelbases were offered: 120, 130, 145 and 156 inches (3.05, 3.3, 3.68 and 3.96 m).
