Old Yella ( until it isn't ! )
Postby KerryB » Sun Jul 06, 2014 10:22 pm
Just got this today, needs lots of work, typical "keep it on the road anyway you can " kind of van. I'm not sure what the front seats are out of but I'm pretty sure they shouldn't be bolted to blocks of wood on the floor ! Steering wheel is not original, fibreglass roof is also not original, should be a pop top, bonnet pins instead of cable release, patch panel welding, but it still has charm :D engine is not original so I think maybe an Essex would be in order. I need to check the gearbox as it has a five speed mk3 gear lever but only 4 gears and it is way too close to the dash for normal driving, either that or I am just too darn short :lol:
KerryB
Re: Old Yella ( until it isn't ! )
Postby ColinJack » Sun Jul 06, 2014 10:25 pm
Yesssss .... :wink:
Need a pic of those seats!
Will be following with interest.
1990 Mk3 Reimo Camper
1980 Mk2 Holdsworth Camper
ColinJack
Postby irishtransit » Mon Jul 07, 2014 1:16 am
She looks a nice van.the hi top should give loads of head height
irishtransit
Postby Retrohowla » Mon Jul 07, 2014 10:49 am
She looks great, even if she does need work, nice van
If you own a transit, learn to weld
Retrohowla
Postby KerryB » Tue Jul 08, 2014 11:42 am
Passenger seat, sprayed at same time as van but drivers has been painted black. Are the blocks of wood to alter the angle of the seat ? Shouldn't this all be boxed in with plastic and have a pivot at the front only or am I mistaken?
KerryB
Return to Mk 1 & 2
