by DougT » Tue Aug 05, 2014 6:04 pm
From 2200kg to 2450kg GVW for Mk1, the GTW is 3250kg for manual transmission & braked trailer. 2850kg for unbraked trailer as if that is any use apart from towing an empty cardboard box !
As it was originally a flat front, I think you will still need to use the petrol engined figure for the front axle weight and I hadn't seen that exemption for motor caravans from LEZ so that is a good spot.
Dodge, I don't see what they can do if it says motor caravan on the V5 ? The under 2.5 tonne exemption for motorised caravans is on their website for all ages of vehicles.
And apart from springs, I can't see that there is any difference in the construction of the vehicle due to the weight limits , so I don't see why you can't just ask DVLA to add GVW of 2300kg to the v5. The only danger is that you need to keep within it and campers are very easy to overload. It is the latest cash machine game of the French police apparently, stopping british reg campers and checking weights....
Doug
