conrod wrote:do keep us updated pls, I know you appear to be having a discussion with yourself at the moment, but I am interested in the results
conrod wrote:cheers Luke,
FYI, I have a Mk3 PS box that I am fitting to a Mk1. I do have the Mk3 drop arm, but have read that the taper to the steering link arm is larger. Probably not a biggie to make a new "hybrid" link arm, but always curious to know if there is a better way to do things.
Luke wrote:that isnt the same with the early mk1 tho - the link bar threads are different - ive got a mk2 link bar i'll have a look at that - at the moment ive got a mk3 non pas box fitted and a mk3 link bar and i cant find the drop arm to fit the mk3 box - the only one ive got i cant split from its box - ive fitted a mk2 drop arm to the mk3 box but as of yet cant fit it to the mk3 link bar
so if what you are saying is right then all i need is a mk2 (or late mk1) track rod end then it'll all fit
Luke wrote:ok to add i think the burhman and the standard are the same fittings - just the burhman one is thicker
