Mk2 4.11 diff ratio?
Postby Aussie Ice Cream Van » Fri Jan 02, 2015 1:10 am
Hi guys just wondering if the mk2 in Australia came with a 4.11 diff ratio?, please let know of you are a mk2 guru. :D
Re: Mk2 4.11 diff ratio?
Postby j6393 » Mon Jan 05, 2015 11:39 am
As far as the manual goes they have 4.625:1, 5.143:1, 045.833:1 for the Mk1 Transits.
If you are interested in a highway diff I have one for sale - I think the ratio was 3.76:1 but I will check the number of teeth tomorrow to be sure.
This is for a twin wheel Transit but after I bought it I realised that my V4 just wouldn't have enough grunt on big hills with this ratio diff.
It uses Transit axles and hubs, but has a Falcon (X series I think) diff centre - it was professionally done and I think the remains of the maker's details are still on it.
j6393
Postby j6393 » Mon Jan 05, 2015 11:42 am
Mistake in the first line should read for the last diff 5.833:1
j6393
Postby j6393 » Wed Jan 07, 2015 10:43 am
Don't know where I got 3.76 from but the crown wheel has 36 teeth and the pinion has 9 making it a 4.0:1 ratio. :D
j6393
Postby Aussie Ice Cream Van » Mon Feb 02, 2015 11:36 am
Hi mate sorry for the delay, thanks for the reply, I have found another hwy diff, its had a chevy 12 bolt conversion done, will definatly keep you in mind if no luck, cheers
Postby South Hem » Tue Feb 03, 2015 8:44 am
So just to get this right there is a 4.01 ratio crown wheel and pinion available as a bolt in conversion for the LWB axle? Is that correct?
South Hem
Postby Aussie Ice Cream Van » Sat Mar 21, 2015 6:53 am
Hi mate, I don't think so, must be my mistake, the only way is to find a converted diff like I have, where a different center has been spliced in, keeping the original axle tubes
Postby conrod » Mon Apr 13, 2015 11:07 am
Mk2 6 cylinder single wheel vans (Oz only) had Borg Warner 78 type diff fitted,(same as a Falcon) & you could get loads of ratios down as low as 2.7 for these.
conrod
Return to Mk 1 & 2
