by DougT » Sun Jan 04, 2015 1:34 pm
I think you may find that the radiator for the 1.6 and the 2.0 are the same. And generally, I would say that if you were to fit an electric fan you will not need as big a rad anyway because the low speed cooling with an electric fan is more efficient than with an engine driven fan.
But if you ask for the seller for the core measurements then you can compare with what you have already.
Doug
