by Ellwood » Sun Jan 18, 2015 3:11 pm
Hi its not hydro, just plain pushrods and adjustable rockers.
engine to be cold when adjusting your settings
inlet .35 mm
exhaust .4 mm
my way, perhaps there is a better one:-
take out all sparkplugs
choose a pair of valves to set
turn the crank until you see both valves are closed
use a soft bendy PLASTIC straw in the plug hole to find when the piston is at top dead center
adjust your valve settings with the funny nut you cant find a socket for. most cheap socket sets have this type of 12 segment sockets in them. im not sure if it is a mm or inch size though
repeat for all 4 cylinders
do you use lead additive in your petrol to help keep the valves alive?
good luck
