by Kedishen » Sun Apr 26, 2015 10:55 pm
Search for Leak off Mod as a common problem is air getting trapped at one of the injectors which must be bled.
Also, common air leak spots are at lift pump connections, and badly fitting fuel filters (on push fit type with black twirl knob) or cracked fuel filter housings.
Having been petrol, there will be a filter on the end of the pipe in tank that gets blocked.. worth blowing the line through...
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
