1982 ford transit mk 2
Postby stortuveien » Fri Jun 05, 2015 10:25 am
Hey guys, does anyone know of cheap wheel adapter from 5x160 to 5-112 (MB) scours the web can not find.
Regards Tor Ove from Norway
stortuveien
Re: 1982 ford transit mk 2
Postby Luke » Fri Jun 05, 2015 4:16 pm
i have re-drilled the hubs on the front of mine to 5x112 for the backs i swapped the axle but you can have adapters made
Postby BROWNYS V6 » Fri Jun 05, 2015 11:04 pm
don't think you will find a cheap hub adapter, mine were £212.00 for a pair :shock:
BROWNYS V6
Postby Indianboy » Tue Jul 20, 2021 6:39 pm
Good day Luke
is it not possible to redrill the rear hub and drum that you changed the complete axel
Indianboy
Postby Luke » Tue Jul 20, 2021 9:02 pm
Indianboy wrote:is it not possible to redrill the rear hub and drum that you changed the complete axel
not with the standard axle as the drub centre bore will have nothing to pick up on
Postby Indianboy » Wed Jul 21, 2021 11:22 am
Good day Luke
sorry i'm not used with this forum yet and i did not see your answers, so in parallel i sent you the same questions this morning by mail :oops:
so now i know why you have changed the rear shaft
I guess i will have to go with a spacer to use alloy wheels
cheers
Indianboy
Return to Mk 1 & 2
cron
