My ex german fire brigade transit was last serviced by the Germans at the end of 2013 before it came to the UK (it's done less than 1000 miles since) I've gone through serviced it now I'm going to change the oil, but it appears to have the wrong oil filter fitted.
From the Burtons site it should have an EFL90 fitted, but for some reason they've fitted an EFL600 which is for a 1.6/1.7 zetec. It obviously fits doesn't leak and works, but is there a reason for fitting this larger filter (better oil flow/filtration? ) or is it simply they fitted the best one they could get.
I'm wondering should I order the correct filter or the same as the one on there.
As far as I can tell it's a standard 1978 2.0 Pinto and the van is all matching numbers as far as I can tell.
The engine:
The filter fitted
