by walt1984 » Sat Jul 11, 2015 6:41 pm
Just a update. Been talking to me dad. Hes at home and im in Cheshire so i cant post a picture so ill try and include everything i understand.
Clutch failed when he was selecting reverse, something went with a bang and drive was engaged.
Removed the gearbox and everything was still in place. The release bearing was still attached to the folk and pressure plate fingers are intact.
But realise bearing has worn a grove into the fingers and he says it looks like they have been hot.
Ive been looking on motomobil web site and it lists borg and beck 241mm clutches for 1.7 and 2ltr v4s and 241mm clutches for 3ltr v6.
Would any 241mm clutch and pressure plate with correct bearing fit ours.?
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
