Thanks, mines a mk2 with a Pinto so I assume some of the mk1 issues won't apply? From what I've seen my mk2 crossmember will fit a Type 9 OK.
Did you rebuild the rear diff yourself then? Are there companies who could do it for me?
So a mk6 4.63 rear diff would fit my mk2 I'd just need a mk4 prop flange? What about the drives shafts do they fit the mk6 diff OK?
