Dear all,
I had to completely rebuild my V4 1.7 Koln engine because the balance shaft came out of its bearings. Having the engine back in the Transit I cannot get it running well. It runs, but is has hick ups all the time and on low gas it stops.
If found out that the rotor in the distribution cap is scratching, it doesn't feel comfortable to me. But I've no experience what is acceptable?
There is also some backlash on the axel which drives the rotor (0,5mm - 1mm).
Thanks in advance.
