DodgeRover wrote:You have an intermitant setting? Was that a custom option?
conrod wrote:where is it located on the mk2? Mine has the intermittent adjuster control on the dash, but steering column stalks do not have the position for it, I think they have been replaced. Would be good to get it going again. Relay will be common to all Fords of that era, Sierra's, Escorts etc.
whitemice wrote:I have the intermittent rotary timer adjust on dash and r/h three position lever switch too and like Neil's van it is an ambulance. both are mk2's.
