mk2 york 2400 diesel overheating
Postby focarglo » Fri Aug 19, 2016 9:59 am
Hi guys,
I'm going crazy.
I have plenty of good coolant, no oil in water, bothupper and lower tubes from radiator get hot, pump is good, but temperature goes on red. Maybe the valve doesn't fully open? Can I bypass it? Thanks
Laika Motorpolo7 on 1982 Transit MkII York engine, Focus TDDi 90cv 2002, Transalp 600 1991
focarglo
Re: mk2 york 2400 diesel overheating
Postby Keef » Fri Aug 19, 2016 11:34 am
Is it actually overheating or is the guage just indicating overheating? Maybe try a new temp sender first.
Keef
Postby Neil » Fri Aug 19, 2016 1:41 pm
thermostat stuck :?: :?:
Neil v6
Neil
Postby focarglo » Fri Aug 19, 2016 2:39 pm
The fan seems to spin free
Shouldn't be fixed when the engine is off?
focarglo
Postby focarglo » Sat Aug 20, 2016 3:01 pm
SOLVED. it was the magnetic control which break down and the fan was spinning too slowly. I just blocked the fan and the axke together and it works
focarglo
Return to Mk 1 & 2
