Mk2 with 5 Speed 2.5 Di
Postby zavricardo » Thu Jan 26, 2017 8:10 pm
Hello,
i was wondering if anyone as encounter this issue.
I have a Mk2 with a 5 speed from a 2.5 di engine, in the gear box i have a digital sensor for the speedometer.
The problem is that my speed cable is mechanic and doesn't fit this gearbox.
What solution can i use?
Can i remove the sensor and apply an old system for a mechanic speedometer?
What changes do i have to do?
Many Thanks for the Support
zavricardo
Re: Mk2 with 5 Speed 2.5 Di
Postby Johny89 » Sun Feb 12, 2017 2:13 pm
my guess is that as you stated an old type sender should fit, get one from a wrecker and you can check it for no big expense.
if it don't fit you can find someone with a 3d printer to fab one for you?
Johny89
Postby Keef » Sun Feb 12, 2017 11:55 pm
Keef
Return to Mk 1 & 2
