HELP! Head gasket gone! mk2 1986 engine replacement
Postby Hazel » Tue May 23, 2017 6:54 pm
Hi all,
I've recently bought a MK2 transit engine 1993cc, she's an ex horse box but has very little power,. I've also just discovered that her head gasket has gone. Yeah its not been the best of days! I really could do with upgrading engine to get more power as she's now a camper with a woodburner, Belfast sink and calories gas bottle so its a lot of weight! I'm trying a bottle of that steel seal gadget repair in the morning just to hopefully tide me over for 2 weeks although I'm not filled with hope! Has anyone managed to fit a 2.3 into theirs??? Also, has anyone had any luck with the green slime gadget temp fix??
Hazel
Re: HELP! Head gasket gone! mk2 1986 engine replacement
Postby Neil » Tue May 23, 2017 8:59 pm
must be a big woodburner if it weighs more than a horse :shock:
Neil v6
Neil
Postby DodgeRover » Tue May 23, 2017 9:33 pm
The standard pinto has the bonus of being very difficult to destroy as well as being very simple and cheap to work on, it's not going to be fast or economical. I would fix what you have.
DodgeRover
Postby Muttley » Tue May 23, 2017 9:36 pm
Nowt wrong with a Pinto (engine not horse) when in good shape, whats wrong with gasket, water loss or compression down?
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby Hazel » Wed May 24, 2017 11:13 am
The radiator is spilling brown water when we stop anywhere. It did it a couple of times the other day then she settled down and the temp remained low for the next 4 hours of driving. The mechanic put a device on the radiator and said if it turns the liquid yellow it means that the head gasket has gone. It turned yellow, he took the device off then the radiator started spitting out brown water and bubbling up. Has anyone had any success with Steel Seal Head gasket fluid?
Hazel
Postby gotgcoalman » Wed May 24, 2017 6:40 pm
Just had a look and to be honest the gasket sets haven't gone up in the 20 odd years since I worked on a "pinto"
Seem to remember earlier engines had spline head bolts and later used torx.
Heads were unlikley to warp (reface either yourself or get an engineering place to do it for a few quid)
Non intereferance engine is a God send :D
Too bloody quiet :shock:
gotgcoalman
Postby Hazel » Tue May 30, 2017 8:08 am
gotgcoalman wrote:Just had a look and to be honest the gasket sets haven't gone up in the 20 odd years since I worked on a "pinto"
Wow really? This is excellent news! Mechanic has quoted me £700!
Hazel
Postby DodgeRover » Tue May 30, 2017 10:32 pm
Did you check your replies in the other forum? Some good points on there.
As a guide for parts prices I had my head skimmed, converted to run on unleaded, fitted new valves and a new hi torque cam + followers and new gaskets for about £300 maybe £350, then there would be labour on top of that.
Someone who knows pinto engines should be able to have the head off, cleaned up and back on in about 6 hours.
If it needs no other work then a full top end gasket set is about £20.
Whereabouts in the world are you, there's probably someone on here who would be able to recommend a mechanic close to you.
DodgeRover
Postby Muttley » Wed May 31, 2017 9:24 pm
I will build you a complete engine for £700!
Muttley
Postby jonochap » Wed May 31, 2017 10:20 pm
Muttley wrote:I will build you a complete engine for £700!
About time you sorted those head locating bolts with all this pinto action!!
Owner of not so troubled puk :)
jonochap
Postby Muttley » Thu Jun 01, 2017 9:29 pm
You have aome :wink:
Muttley
Postby Hazel » Mon Aug 21, 2017 3:54 pm
An update:
The pinto head gasket had completely gone. She now has a 2.5L diesel banana engine and 5 speed gearbox and is oh so much better! Thanks for all the advice :)
Hazel
Postby DodgeRover » Tue Aug 29, 2017 12:05 am
Do you still have the old pinto?
DodgeRover
Return to Mk 1 & 2
