The van had its first proper run out this weekend with no major issues covered a couple of hundred miles.
Two points I'm looking for advice on -
1) Squeaking - when it has been driven for a long period it starts to squeak from the wheels at low speeds only. If I slightly apply the hand brake it goes.
2) The carburettor drain is leaking when it's turned off. The van smells like its runny slightly rich and the idle is lumpy to which I have to turn the idle screw up slightly. After turning off its drip......drip..... for a bit through the tube that runs from the carb by the battery on to the floor. I'm guessing this is to do with the carb bowl??
