Bull nose to flat front
Postby Boffin » Tue Nov 28, 2017 8:36 pm
Hi guys, I have a bull nose mk1 van, I'd like to put the flat front on. Has anyone done this? And what is different? I know the bonnet and front panel obviously, think I saw somewhere the wings are different?? And is it easy to swap the panel below the front panel? Are the spring hangers to far forward?? I already have a petrol front bumper.
Thanks for any advice :)
Boffin
Re: Bull nose to flat front
Postby Muttley » Tue Nov 28, 2017 10:40 pm
Why is yours a Bull nose? If it has a diesel engine or a Pinto petrol then the flat front wont fit.
Expert burns receiver.
Bodger Extraordinaire!!
Fallen in love/hate with Mk6s
Muttley
Postby dumper » Wed Nov 29, 2017 12:28 am
The chassis legs are longer the front x member is further forward the wings are the same
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Luke » Thu Nov 30, 2017 12:04 am
Boffin wrote: Are the spring hangers to far forward??
no they are in the same place :)
Postby Boffin » Thu Nov 30, 2017 1:17 pm
Thanks chaps, I have seen a pinto in a flat front before though.
So to do it I can keep the spring hangers in the same place maybe shorten the chassis rails and try and get a new flat front crossmember (bit behind the bumper)
Thanks again chaps :)
Boffin
Postby Luke » Thu Nov 30, 2017 9:41 pm
the chassis rails only need shortening in front of the front spring hangers
also pinto's are squeeze in a flat front and now old hat,.......... get a zetec in there - shorter so more room for one too :D
Postby dumper » Thu Nov 30, 2017 10:29 pm
When I fitted a 2.0 Lt in to my mk1 v4 I left the flat front bumper as is but I used a bull nose front and bonnet and a York radiator the front of the pinto just cleaned the front x member
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Muttley » Thu Nov 30, 2017 10:45 pm
Pinto will go in a flat front but needs modification to radiator and removal of fan. What I asked is why you have the bull nose, if you have a diesel then flat front deffo wont fit. If you have a Pinto in there then you will have to do work on the front of the engine and radiator or move the engine back. I find the most succesful way is the latter :wink:
Muttley
Postby dumper » Fri Dec 01, 2017 1:02 am
Or cut the x member and front or chassis legs off and weld in flat front x member
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby Muttley » Fri Dec 01, 2017 10:38 pm
That still wont help with the clearance at the front of the engine :wink:
Muttley
Postby dumper » Sun Dec 03, 2017 11:48 am
True but to turn it in to a flat front you still have to cut the chassis legs and x member.its a hell of a lot of work to move engine back if it was me and I really wanted to fit a flat front I’d fit a 1600 cc Kent engine in
dumper
Postby Boffin » Sun Dec 03, 2017 7:23 pm
Thanks chaps, I'm not worried about engine as I can modify anything to go in. I was just wondering the difference between the 2? So the wings are the same, different front panel and bonnet (obviously) and just shorten the chassis rails to fit a front petrol/flat front crossmember, get rid of the bull nose bumper and extension bits and use flat front bumper.
Are the flat front crossmembers available any where?
Thanks for your help chaps.
Boffin
Postby Muttley » Sun Dec 03, 2017 10:50 pm
You cant buy any Mk1 panels except s/h or nos. Expect to pay a lot of money in any case :wink:
Muttley
Return to Mk 1 & 2
