I really hope someone can help me, I have a 1983 Transit MK2 (or MK1 facelift model depending on your point of view) single rear wheel camper. At the last Controle Technique (French MOT) the tester told me the rear axle was leaking oil. I removed the 1/2 shaft & bearing carrier to get at the oil seal....it was quite banged up & distorted as thought someone had removed it and replaced it.
I managed to source a modern neoprene replacement but it still leaks a little. The original is a neoprene seal seated in a metal carrier which is then pressed into the hub.
So the question is does anyone know where I can get a replacement. The part no stamped on the seal is 76VB-1175-CA
Can ayone help?
