1978 Transit ft100 mk1
Postby migl » Sat Mar 31, 2018 5:10 pm
Hi from Portugal.
I am now a proud owner of a 78 Transit mk1 with sliding doors!
the first restoration i would like to do is changing this plate
but im not been getting the right way to remove the upper cover, it is stuck in the back, and with 40 year's old plastic im too scared to do much pressure.
Does anyone have an exploded image of the dashboard? I can only find some in the interwebz but not what i need.
Thanks in advance,
Miguel
migl
Re: 1978 Transit ft100 mk1
Postby Luke » Sat Mar 31, 2018 6:35 pm
nice van 8)
you need to take out the 2 screws you can see in the photo then it just pulls straight up - you will be able to feel under the dashboard to get to the 2 clips if you push the centre of them with a screwdriver it will help it come up :D
Postby migl » Sat Mar 31, 2018 7:02 pm
i forgot to tell but i removed those visible front screws and under i cant seem to get to the clips... thats why i asked, i was afraid that there were more screws under.
Thanks! ill try it again
migl
Postby ned » Sat Mar 31, 2018 7:44 pm
Nice, very nice, any more pictures 8) N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby migl » Sat Mar 31, 2018 9:28 pm
ned wrote:Nice, very nice, any more pictures 8) N
got a few here...
Are these seats original ? never saw them in catalog
migl
Postby Neil » Sun Apr 01, 2018 8:24 am
yes most lhd have those seats van looks nice and original,,, remove the two lower screws and holding strip then reach your hand under on the speedo and gently push,,,,, the face panal should move forward the speedo cable may be holding it tight
Neil v6
Neil
Postby migl » Sun Apr 01, 2018 9:55 pm
Neil wrote:yes most lhd have those seats van looks nice and original,,, remove the two lower screws and holding strip then reach your hand under on the speedo and gently push,,,,, the face panal should move forward the speedo cable may be holding it tight
Yeah got it out but now can't remove the speedo cable
How the hell do I remove itImage
Sent from my Redmi Note 4 using Tapatalk
migl
Postby blue estate » Sun Apr 01, 2018 9:58 pm
Push cable in a little then push white collar to one side and pull
blue estate
Postby migl » Sun Apr 01, 2018 9:59 pm
Thanks will try again tomorrow
migl
Postby Toofast » Wed Sep 18, 2019 5:15 pm
I love your van, I have just the next model of that, just when they changed the nose, but also with the sliding door. Right now I am restoring it, you will not know where you can find the rubber of the sliding door
Toofast
Return to Mk 1 & 2
