battery cut-off relay, what type?
Postby peteMK2C » Sun Jan 28, 2024 2:53 pm
Hello everybody,
I'm from Germany and new on the forum.
Running a beautiful 1985 Facelift MK2 Arca Camper with 2.5 DI Engine.
The motorhome has a relay installed on the right-hand wheel arch. Probably a battery cut-off relay.
Here are 2 pictures:
Does anyone here know the relay, or does anyone know exactly how it works and what specifications it has? Spare part number or similar... ?
If I could get some information about it that would be fantastic. It still works, it's just that I would like to know exactly what it is and how it works.
Thanks,
Pete
peteMK2C
Re: battery cut-off relay, what type?
Postby dumper » Sun Jan 28, 2024 8:24 pm
It doesn’t look like a Ford part with the crimp on terminals maybe a split change relay with it been a campervan.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Chug » Sun Jan 28, 2024 10:38 pm
It's an old type solenoid relay, its basically just like a starter motor solenoid, just search for "round solenoid relay" if you want one the same, but you could use a square one, or even swap it for a modern relay, its just a switch really, the yellow and black wire going to the small terminal will be the "trigger" to switch the power between the two big terminals
Chug
Postby peteMK2C » Mon Jan 29, 2024 12:49 pm
Thanks for the help!
Searching "round solenoid relay" gave me in deed right away a dealer address for both, the old tin can design and the newer square versions of high-load relays.
peteMK2C
Postby peteMK2C » Tue Jan 30, 2024 4:32 pm
As a matter of fact... I found out, it IS the Starter-Motor-Solenoid
I was wondering, does anyone know if this Relais position, e.g. mounted on the wheel arch, is standard on all MK2 Transits?
peteMK2C
Return to Mk 1 & 2
