by FredTransit » Mon Jun 02, 2008 5:55 pm
OK, as the owner of plenty of Mk2s, petrol and diesel, factory diesel and conversions, 2 ambies (V6) and pinto powered LWB and pinto powered lutons I will throw in my twopenneth.
What's your amby's back ground? Was it front line or patient transfer, NHS, St Johns or Red Cross? Your amby is likely to have spent it's early life as a V6 Essex, and as a fairly thirsty engine was likely to have been returned (would have left Ford as a 2L petrol) to pinto power by a former owner. Both our Hanlon and Wadham Stringer ambies (different manufacturer/converters) started life as 2L petrols, according to the VIN plates (much to my surprise). Bear in mind the glass fibre body is quite heavy, which is why your pinto won't be that fast. A good option is the twin choke, and bear in mind your engine may be a later one from a Mk3/4 and could be unleaded. All our pintos are replacements, and are unleaded.
An optional engine would be a DI diesel, with 5 speed gearbox. we have this petrol to diesel conversion on some of our lutons, and only changed the front springs due to load carrying. Your ambulance will have huge springs, maybe 4 or 5 leaf, and shouldn't need changing. If you went for a DI with a bosch pump, as already mentioned, you can run it on up to 60% veg oil (even waste veg oil) in the summer and 40-50% in the winter without alteration.
