Leaky sump
Leaky sump
Postby sam l » Wed May 20, 2009 4:18 pm
Hi - just got Brian through the MOT at a cost of £1100 . . . now it seems that the advisory slow oil leak is from the corroded sump and a new one (+gasket) from Ford is £243. Is that the best option given that one from a scrapper will probably be on it's way out too?
It's definitely the sump.
Ta
sam l
Re: Leaky sump
Postby rover » Wed May 20, 2009 7:02 pm
And the engine is?????????????????????????????
rover
Re: Leaky sump
Postby Luke » Wed May 20, 2009 7:03 pm
well whatever the engine turns out to be :lol: you could chemical metal the sump :idea:
Re: Leaky sump
Postby sam l » Wed May 20, 2009 9:55 pm
Sorry yes should have said 2.5DI lucas pump vac pump on alternator I think it's an 86?
I thought of epoxying the sump but it really does look pretty chuffed and I'd have a right old time getting all the oil etc off it first.
sam l
Re: Leaky sump
Postby Luke » Wed May 20, 2009 9:57 pm
cant you get a sump from beevers :?
http://fordtransit.org/ad/redirect/21/ :D
Re: Leaky sump
Postby Luke » Wed May 20, 2009 9:59 pm
yeah you can just checked and it's a lot cheeper than fords :lol:
part no. 30-51-725
Re: Leaky sump
Postby sam l » Wed May 20, 2009 10:06 pm
I'd never heard of them but cheers for that! Will have to tell Ford to un-order it . . .
What a price difference - only a bit of bloody metal isn't it £243 is outrageous.
Cheers
arrgh and they've got long arm mirrors (MKIII but still) for 20 quid!
sam l
Re: Leaky sump
Postby Luke » Wed May 20, 2009 10:08 pm
they sponsor the progress section on here :D when you order it mention you got their name off here 8)
Re: Leaky sump
Postby FredTransit » Wed May 20, 2009 10:41 pm
sam l wrote:I'd never heard of them but cheers for that! Will have to tell Ford to un-order it . . .
Cheers
You can't fit Mk3 mirrors to a Mk2, they are totally different fittings and they would look pants!
FredTransit
Mk2 Trannyist
Re: Leaky sump
Postby Luke » Wed May 20, 2009 11:07 pm
Cheers
here they are on a mk1 :shock: :shock:
Re: Leaky sump
Postby sam l » Thu May 21, 2009 10:08 am
Clearly you haven't seen my van!
I'm just sick of not being able to see behind me, and proper MKII mirrors are not to be had. As it happens I'm building my own out of UTM's and pipe - which will look truly vile!!!
sam l
Re: Leaky sump
Postby madmark » Thu May 21, 2009 2:02 pm
Cheers
ah memories ,mind you it did have good vision looking out of them! even tho it was left hand drive!
but fred is right they looks pants! :wink:
Re: Leaky sump
Postby Retrohowla » Thu May 21, 2009 6:43 pm
sam l wrote:Hi - just got Brian through the MOT at a cost of £1100 . . . now it seems that the advisory slow oil leak is from the corroded sump and a new one (+gasket) from Ford is £243. Is that the best option given that one from a scrapper will probably be on it's way out too?
Ta
Cheap after market ones on ebay, dunno how £47 delivered compares to beevers?
.co.uk
If you own a transit, learn to weld
Retrohowla
Re: Leaky sump
Postby sam l » Tue May 26, 2009 4:01 pm
It's a bit cheaper - think Beevers was about £90 including gasket (pricey) and delivery.
sam l
Return to Mk 1 & 2
