Transit Mk1 1977 engine/gearbox swap
Re: Transit Mk1 1977 engine/gearbox swap
Postby manandvan » Sat Sep 12, 2009 10:56 pm
hi for your van, overdrive gearbox would be the favourite option, if you can find one?? they are still about in the u.k. or you could go for the mt75 wich will bolt straight onto your 2.4 but you need to alter the floor and weld/modify the gearbox cross member, but you can use factory spec propshaft off same wheelbase van :D
manandvan
Postby manandvan » Sat Sep 12, 2009 11:05 pm
also you could turn it up on the pump for more speed, is it bosch or cav minimec?? do the tappets on it also, this makes a big difference, 0.0013 inch clearance on all (cold engine) :D
manandvan
Postby Hellblazzer » Tue Oct 06, 2009 11:25 pm
Hi there fellas.
pedropinto, are You the user I spoke with at MotorClassico? :wink:
Love to see that there are more Portuguese Transit lovers in here :D
I have a 1982 for sale http://www.standvirtual.com/index.php?a ... id=P716149
And a 1986 2.5di daily worker 8)
Good luck to all the transit owner's projects!
________________
Olá pessoal.
Pedropinto, és o utilizador com quem falei no MotorClássico? ;)
É bom ver que há mais Portugueses que gostam de Transits por aqui :D
Tenho uma de 1982 à venda http://www.standvirtual.com/index.php?a ... id=P716149
E uma 2.5di de 1986 a andar todos os dias 8)
Boa sorte com os projectos de todos os donos de transits :D
-1986 Mk3 2.5di 80ps banana engine and some more mods-
Hellblazzer
Postby whity » Wed Jul 04, 2018 11:02 am
Hi all,
I know that this topic is quite old, but I wonder if there is any feedback about it.
Did anyone got further with this swap?
Cheers
whity
Return to Mk 1 & 2
