MK1 Essex Overdrive fits the same way the 4 gear box fits?
Postby phaidros » Sat Apr 24, 2010 7:54 pm
:D
am running an '74 firewagon here in Germany, but am annoyed about the
4 gear box. So I am thinking about getting myself an overdrive.
As I have the Essex V4 engine it is quite difficult to find docs and references
about that, because most people here drive the cologne V4 engine.
I'd really need to know, what needs to be changed / replaced when I'do to
replace my 4 gear box to an overdrive. Any hints and ideas about that?
Or would it be just plug'n'pray?
thanx!
I love deadlines. I like the whooshing sound they make as they fly by.
Douglas Adams
English humorist & science fiction novelist (1952 - 2001)
phaidros
Re: MK1 Essex Overdrive fits the same way the 4 gear box fits?
Postby not-a-jappa » Sun Apr 25, 2010 10:49 am
Pretty sure that the back gearbox mount is different and the propshaft is a different length.
Baconsdozen knows about this.
Other than that as we describe it "suck it and see bro"
Some days you're the statue, other days the pigeon.
not-a-jappa
Postby phaidros » Sun Apr 25, 2010 11:06 am
Well, so then I'll just go for it!
thanx for the hints!
Douglas Adams
phaidros
Postby madmark » Sun Apr 25, 2010 12:22 pm
hi phaidros
you will need a gearbox and crossmember and propshaft from a essex 3ltr transit :wink:
Postby baconsdozen » Mon Apr 26, 2010 10:24 am
You also have to alter the exhaust down pipes to stop them hitting the crossmember.If its the older type box that hangs from a mounting that attaches to the top,the old monut will have to go.
baconsdozen
Return to Mk 1 & 2
