MK2 with Sierra gearbox
Postby chrisrotlmacin » Sat Feb 26, 2011 7:48 pm
I just purchased a MK2 Diesel 2.5 with Sierra 5 gear gearbox . The original gearbox got broken .
The gear changer is about 40 cm back of his original position .
Any one else with this change ???
chrisrotlmacin
Re: MK2 with Sierra gearbox
Postby Greg L. » Sat Feb 26, 2011 8:02 pm
Intersting ! I would like to go for a 5 speed gearbox for my Transits. Do you have any information about your gearbox or the car it comes from ?
Greg L.
Postby chrisrotlmacin » Sat Feb 26, 2011 8:27 pm
Greg L. wrote:Intersting ! I would like to go for a 5 speed gearbox for my Transits. Do you have any information about your gearbox or the car it comes from ?
From Ford Sierra .
chrisrotlmacin
Postby Luke » Sat Feb 26, 2011 9:20 pm
is it an MT75 or a type 9 (where is reverse gear)
if its a type 9 (reverse up next to 1st) you can get the transit type 9 stick and it will bolt onto the top of the sierra box :D
if its the mt75 ................. you cant :)
Postby Luke » Sat Feb 26, 2011 9:22 pm
this is the type 9 with the transit stick :D
Postby chrisrotlmacin » Sat Feb 26, 2011 9:30 pm
Is type 9 i guess , reverse is up next to first but i have to push de gear changer to go in reverse . The handle is short :D i will try to extend it .
Thank you guys for your answers . Is any one has any documentation on this gearbox ??
chrisrotlmacin
Postby Luke » Sat Feb 26, 2011 9:34 pm
if you get the transit stick like what is shown in the picture it will bolt onto your sierra box and you can take off the origanal sierra stick - then your stick will be in the correct place and the right length :D
Postby chrisrotlmacin » Sat Feb 26, 2011 9:54 pm
Luke wrote:if you get the transit stick like what is shown in the picture it will bolt onto your sierra box and you can take off the origanal sierra stick - then your stick will be in the correct place and the right length :D
From what transit model is the type 9 stick ?? The previous owner told me that the original stick was not used because the gear changer with sierra gearbox is between the chairs . I apologize if my questions are too much , i am just discovering my MK2 that i purchase today . Huge difference , more heavy .. feels like i drive a tank .. that front bumper (tick metal) is scary against any regular car that is build the present .
chrisrotlmacin
Postby Luke » Sat Feb 26, 2011 9:55 pm
you can get the stick from a mk3 transit 1986 - 1988/89 :D
Postby Inline Boarding Portugal » Sat Jun 25, 2011 3:22 am
Does anyone have an exploded view from the inside of the selector case?
I'm pretty sure that in our older transit ('81 mk2) it's missing some part inside..
-Very often the stick get blocked and then it's impossible to change gears. We must take off the entire stick and re-align the (3) "plates" in order to un-block the mechanism
Can anyone please help?
Every now and then being lifted by:
-> '85 DI MK2 phase2 Grey Minibus
-> '81 York diesel MK2 phase1 White Minibus
## INLINE BOARDING PORTUGAL ##
Postby transitgeoff » Sat Jun 25, 2011 7:35 am
i take it you havent changed the stick position then luke :?: that box wont last long in there as the input shaft on a sierra is shorter and is not reaching into the spigot :wink: and to change the stick you also need to change the tail section and i wouldnt advise a diy job on that :) enjoy it while it lasts :lol:
transitgeoff
Postby Luke » Sat Jun 25, 2011 10:08 am
sierra diesel has the longer input shaft :D why do you need to change the tailshaft :?: mine wasnt changed :)
Postby transitgeoff » Sat Jun 25, 2011 6:38 pm
well how did you select gears then :?: the sierra has the selector rods in the tail piece :?
transitgeoff
Postby Luke » Sat Jun 25, 2011 6:40 pm
transitgeoff wrote:well how did you select gears then :?: the sierra has the selector rods in the tail piece :?
using the transit stick it picks up on a different part of the selecter rods- once the sierra stick is off as you select gears you can see the sierra linkage move :D i think i might have one still somewhere :?
Postby bortaf » Sat Jun 25, 2011 10:48 pm
Any help?
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Return to Mk 1 & 2
