oil level dropping....
Postby mavis cruet » Thu Sep 08, 2011 4:22 pm
on a recent long hot motorway trip (55mph) the oil pressure on my mk camper dropped gradually by about 15psi. when left to cool it increased a bit. now, on short runs to work it seams to be still dropping but only a small amount. its hovering round the 45psi mark. could this be the oil pump? is this a major job? there seems to be no increase in the amount of oil used, and what is used seems to leak from various gaskets and some out of the oil filler cap, as always. any advice apreciated. karl.
mavis cruet
Re: oil level dropping....
Postby Ollie » Thu Sep 08, 2011 4:37 pm
I'm presuming V4? are you measuring pressure with the dash guage? My V4 allways dropped to the point of warning light flashing after a long motorway run and its still going! so long as pressure goes back up when its revving I wouldn't worry too much.
If the oil is recent and good quality then I'd just leave it alone, if youre using a modern 10w40 or such like the get some good old 15w 50 or even 15w 60 and give it a change which can't do any harm.
The oil pump is driven by the distributor drive through a little hex shaft and when these where new they were prone to rounding off so if you feel like it you could tweak that out and check its driving ok.
Ollie
Ollie
Postby mavis cruet » Sat Sep 10, 2011 11:13 am
yes its a v4. its got 20/50w oil in. ive an oil pressure guage fitted and the drop in pressure mentioned is at 50mph or there abouts. im going to try a new guage and see what happens.....
mavis cruet
Postby transitandy » Mon Sep 12, 2011 10:26 am
let us know what happens :wink:
Postby Chaz&Saz » Mon Sep 12, 2011 5:46 pm
The oil pressure dropping when hot is normally a sign of general wear. As the bearings loose there thickness the gap between them and the crank journal get larger causing less restriction and a drop in pressure. As the oil get hot it gets thinner hence the higher pressure when cold.
As suggested take a look at the drive shaft for preventive maintainance. Would also be worth looking at the pump pick up as it may be blocked by years of sludge.
Hope this helps
1972 Built, 1973 Registered, Land Liner V6
1967 Triumph Herald - Bethany
1976 Triumph Dolomite
Chaz&Saz
Postby mavis cruet » Thu Sep 15, 2011 1:08 pm
cheers. will have a nose when i get the chance....
mavis cruet
Return to Mk 1 & 2
