chth1812 wrote:Hello,
Can somebody let me know which is the appropriate (original) Lucas pump type for a 1995 2.5Td 85HP Transit? I bought the car last year but it has problems in accelerating and switching off. Could this be related to connection between the ECU and the pump?
Sounds like the ESOS plunger has gone
(Electronic Switch Off Solenoid)
The pump has to take alternative action to switch the engine off and you will have reduced power when switched on
If you want full power, remember to stall the engine as you switch it off to fool the ECU into thinking the ESOS is working
In the meantime, search ESOS on the forum and find the how to change it
