Altransit wrote:There is nothing on earth that stops rust once it has taken hold, the best you'll do is slow it down a bit![]()
Only new metal will solve the problem
n8rbos wrote:Cut out all the rot, either plate covered with Glass fibre mix and stick to underside, let it go off then fill top hole with fibre glass sand down( better to use the grinder with a flapwheel) then smooth out with filler, prime then paint. Done properly it'll last years. Just wire brush under the arch to give the fibreglass more to hold onto, then smoothout and underseal over.
Regards tekaloid (or alkyd has its really called) if you get a litre @£10 ,thin down 20% thinners 80% paint and use a cheap mini roller from b&q with the gloss roller, build up thin layers you'l have no brush marks
