pilot/flywheel spigot bearimg
Postby gotgcoalman » Mon Mar 27, 2017 10:13 pm
would i be right in assuming ............
pilot bearing is a 15/35/11mm for a Di flywheel?
I refuse to pay £20-£30 for a bearing which i can get for £3.52 delivered. (either SKF or NSK)
Too bloody quiet :shock:
gotgcoalman
Re: pilot/flywheel spigot bearimg
Postby F111ORY » Tue Mar 28, 2017 8:17 am
Correct. Thats just what I did.
F111ORY
Postby gotgcoalman » Tue Mar 28, 2017 5:40 pm
just had a comformation email from simply bearings.
SKF bearing dispatched royal fail 1st class.
It was a bit more than expected.
forgot prices are ex VAT :oops:
It was £4.22 delivered :D
gotgcoalman
Postby CamperVanBeethoven » Tue Mar 28, 2017 10:45 pm
Royal Fail, but Bargain Win :)
CamperVanBeethoven
Postby gotgcoalman » Wed Mar 29, 2017 3:56 pm
Ordered yesterday,it did indeed arrive today :D
only changing it as a precaution.
gearbox oilseal and crank oilseal bought aswell.
One or both the seals are weeping so I might as well do the pair while the
box is out.
gotgcoalman
Postby V184 » Wed Mar 29, 2017 5:44 pm
the crank oilseal plate gasket pee out :wink:
V184
Postby gotgcoalman » Wed Mar 29, 2017 8:36 pm
V184 wrote:the crank oilseal plate gasket pee out :wink:
Not sure if it's crank or gear box.
Both needed a little top up and there's no definate smell to the nasty oily crap in the bell housing.
SO.......
do both deals and the pilot bearing.
check the clutch condition while i'm in there.
local motor factor has several branded clutch kits in stock so if thats a bit iffy i'll
put a new one in.
the joys of motoring :wink:
gotgcoalman
