K reg intermittent fault help please
Postby tig190 » Fri May 18, 2018 10:18 pm
Hi all it's been a while.
I've just had my mk 4 in for it's mot passed with no advisorys
But on the way back it's developed a fault where it's drives fine then won't rev just ticks over turn it off start it up its fine again then after a few miles does it again. The only thing that has been done to it is a new cold start fitted that seems to be when the trouble started.
Diesel must be getting through for it to tick over but I can't understand why it won't rev even pulling it manually timing belt is only a year old and it all locks up in line with the pins.
Any advise would be great thanks in advance
tig190
Re: K reg intermittent fault help please
Postby Chug » Fri May 18, 2018 10:44 pm
Is this the Bosch VE pump?
And its not revving up when throttle lever pulled by hand?
But switch off engine and restart and its fine?
Chug
Postby tig190 » Fri May 18, 2018 10:47 pm
Not sure about pump I'll have a look in morning but yes that's what it's doing it'll be fine for a while then just no revs it's driving me mad haha
tig190
Postby tig190 » Fri May 18, 2018 10:51 pm
I forgot to say it's a 190 2.5 di 80ps engine
tig190
Postby Noctule » Sun May 20, 2018 5:12 pm
How is the tickover when it happens? Lumpy or smooth?
2000 Mk5 HiCube self-build camper
- 2.5tdi 4EA with EPIC-to-Bosch conversion
- DRW with 16" rims
- Mondeo instrument cluster
- Lunar Meteorite interior
2006 Mk7 115t350 van (cheap tax tramp)
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby Noctule » Sun May 20, 2018 5:14 pm
And when was the fuel filter last changed?
- DRW with 16" rims
Previously...
Mk5 100 swb Custom
Mk5 190 lwb x3
Noctule
Postby cherniy_chack » Sun May 20, 2018 6:34 pm
This behavior of the motor is typical for the EPIC system, but not for the BOSH system.
cherniy_chack
Postby tig190 » Thu May 24, 2018 9:25 pm
Sorry for the late reply I've been away
The tickover is smooth and the fuel filter is new it's also had a new fuel pump on the block and a new cold start but that's when it seems to have started when ford put the cold start on but they're not having none of it as usual haha.
I'll check the fuel system on Saturday to see which one it is
tig190
