I have finally got round to taking off my dash and removing the tacho to fit the speedo cluster i bought months ago.
On removing the tacho i saw that it is not run via a cable but by some sort of digital means via a two plug connection.
The original speedo instument plug is still intact, but a home-made splitter has been installed to route the fuel+temp to the right of the tacho and the warning lights to the right. After removing this splitter i was able to plug the long combined plug into the speed cluster and have full functionality...thank god.
The only problem i now have...and the problem that i started with...is that i have no speed or mileage readout. I need to install a cable from the back of the cluster to the gearbox.
There is no sign of a cable behind the dash anywhere so i am assuming that it was removed when the tacho was put in.
In the event of a total absence of speedo cable and fitting at the gearbox end, what is the process for installation?
Obviously i need to run a cable from the cluster to the gearbox, but what about attaching the gearbox end of the cable to something.
What is the 'something'? Can i fit it myself? Should it be there already? What does it look like?
Many thanks.
