aftermarket alarm and central locking kits.
Re: aftermarket alarm and central locking kits.
Postby Rickbu » Sat May 11, 2013 11:29 pm
Right here you go mate. This is how it's supposed to be done, found the post viewtopic.php?f=13&t=66286
1998 county X2 one daily use one waiting restoration
2000 mk5 self build motorhome restored and built
1995 Isuzu trooper 3.1 td
2000 astra 1.7 td Isuzu power conversation
Rickbu
Postby evilgoat » Sun May 12, 2013 10:14 am
I did attempt to remove the lock with a view to looking at this, due to time contraints (I was informed with bits of the van all over the car park she wanted to go out at 3) I gave up. Is there a trick to getting that lock mech out cause I couldnt see an easy way to do it, no movement in any direction, well not enough to get it out without taking the regulator out as far as I can see.
evilgoat
Postby Rickbu » Sun May 12, 2013 10:32 am
Yes it is hard, I had to remove the white plastic bit before it would come out once you take that off you can twist it sideways and it just squeezes out it's tight but it does come out, I agree no good if your being rushed !
Rickbu
Postby awdriver96 » Sun May 12, 2013 11:45 am
These people have lock repair kits and sets, the repair kit allows you to select the right wards to still use the original key
( the locks wear far more than the keys) so you still have your original immobiliser chip and no messing with the electronics side, simpler and cheaper, I have used a number of these and once youve done one they are a piece of cake, this ad is for the ign lock but they have the door ones too, you usually only need to do ign and drivers door, for obvious reasons.
mt
http://www.ebay.co.uk/itm/110383563333? ... 1423.l2649
awdriver96
Postby Rickbu » Sun May 12, 2013 12:57 pm
That's quite pricey! you can get full lock set with keys for that but your right about the chip, you have to get a new one cut or just keep the old one on your keyring like I do and hold it near the barrel when you start with The new key. Sorted
Rickbu
Postby awdriver96 » Sun May 12, 2013 9:08 pm
Like with everything you get what you pay for, i have bought the cheapos and had loads of greif with them, these are ford ones as original.
mt
awdriver96
Postby Rickbu » Sun May 12, 2013 10:18 pm
Luckily all My cheap ones are working fine and were easy to fit , every lock on the same key :)
Rickbu
