Mondeo Dash ...again.
Re: Mondeo Dash ...again.
Postby robbie.cee » Tue Feb 15, 2011 10:00 pm
It seems that the lamp for fog lights in clocks may have some reversed wiring - somehow?
its like the lamp gets a perm 12v feed into its + term, not switched,
the - term of lamp is most likely connected to the switched 12v feed from fog lamp switch, so ,
as fog switched off, the dead leg to the relay is long enough for the warning lampo in dash to see it as a route to earth.
voila lamp on when off!!
gonna be fun reversing polarity on just one lamp! hope this helps
rob
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby turnippits » Sun Feb 27, 2011 7:59 pm
right first time i have posted on this one i have a transit 130l it is a factory fitted 15 seat minibus n reg 1996 smiley it has the 3 terminal alternator with 3 wires attached yahoo it has the best wiring harness in electic window pack inside the doors even though it does not have electric windows it is a cable speedo this i know because my trip reset is on the left of my gaugue so what year clocks will i need out of
a a mondao
b a transit
c a tournao
any help would be gratefully recieved also does anybody know what i should be paying for 1 i also need to change my indicator switch has it does not cancel itself :P :P :P
turnippits
Postby the.little.fatboy » Sun Feb 27, 2011 9:11 pm
turnippits wrote:right first time i have posted on this one i have a transit 130l it is a factory fitted 15 seat minibus n reg 1996 smiley it has the 3 terminal alternator with 3 wires attached yahoo it has the best wiring harness in electic window pack inside the doors even though it does not have electric windows it is a cable speedo this i know because my trip reset is on the left of my gaugue so what year clocks will i need out of
a a mondao
b a transit
c a tournao
hi i belive its from 1995 to 1997 ones after that they went electric i think im sure the pro's will no for sure tho
if it brakes fix it if you cant fix it scrap it and buy a ford transit
also collecting scrap metal in northampton and milton keynes area's
the.little.fatboy
Postby AndyG » Sun Feb 27, 2011 11:21 pm
a a mondao
b a transit
c a tournao
Why have all this mondeo hassle/half the time don't work clocks, when you can simply plug and play with the proper/official n/a clocks :?:
:arrow:http://cgi.ebay.co.uk/FORD-TRANSIT-CUST ... 2c5a7882e7
And that price includes the post too :!:
Postby robbie.cee » Tue Mar 01, 2011 4:48 pm
a a mondao
b a transit
c a tournao
lol join the club same ere m8!!!
live with it n spend the money on beer instead!
Had
MAKE IT FIT
robbie.cee
Postby markbatty » Thu Jun 23, 2011 8:26 pm
Just fitted some mondeo clocks and its reading 5000 revs on tick over has anyone found out why it does this yet and fixed it ? ?
markbatty
Postby robbie.cee » Sat Jun 25, 2011 3:38 pm
is it reading backwards? does it rest on 6k + when engine off?
Had
MAKE IT FIT
robbie.cee
Postby markbatty » Sat Jun 25, 2011 4:50 pm
Yes it is :|
markbatty
Postby robbie.cee » Sat Jun 25, 2011 4:58 pm
d'oh!!! get searching m8 sure i seen some thing like that somewhere!
Had
MAKE IT FIT
robbie.cee
Postby maciejd » Sat Jul 28, 2012 5:33 pm
Does asnyone found a solution for the 4800-5000 on Mondeo rev counter?
I had Transit clocks cluster with rev counter, but sometimes it was hanging, showing much lower revs than it should or simply zero.
I was thinking that was caused by the alternator which was dying slowly. I bought a new alternator a few days ago, but there is no improvement with the rev counter.
Today I bought Mondeo clocks, scaled to 6000, with D printed. The original rev counter was marked 97VP, the mondeo one is 97BP.
There is no matter if I connect whole mondeo cluster or only swap the rev counter to the original cluster, it shows something like 4-5k revs on idle.
Is there any solution? Finding original Transit rev counter at reasonable price in Poland is almost impossible :(
regards, Maciej
It's not about driving a van. It's about Ford Transit.
1996 FT Van, 525 000 km - restoration / progress report topic
2004 FT Euroline, 150 000 km - progress report topic
2008 Renault Clio, 40 000 km
2011 Renault Laguna, 90 000 km
maciejd
Postby Mfr » Sun Jul 29, 2012 11:43 am
Have a read of this viewtopic.php?f=4&t=104398 What year was the Mondeo you got the clock from? and was it petrol or diesel?
Mfr
Postby IgorVigor » Sun Jul 29, 2012 12:00 pm
Out of interest, do the Mondeo clocks have an adjuster in them?
potentiometer perhaps?
I have used an old LR Discovery rev counter in my transit.....
just so I can see spool RPM and max RPM...
that has a potentiometer that alters the engine speed reading.
IgorVigor
Postby maciejd » Sun Jul 29, 2012 2:02 pm
Mfr wrote:Have a read of this viewtopic.php?f=4&t=104398 What year was the Mondeo you got the clock from? and was it petrol or diesel?
The Mondoe clocks are from a diesel.
The clocks I've got fitted are from 98-99 Transit and are fully electrical ones: 98VP-10C956-FB.
The Mondeo clocks I try to swap the rev counter from are 98BP-10C956-HB and are electrical as well. I assume the Mondeo was post 1998 then.
Ok, as per viewtopic.php?f=4&t=104398 I'll try to find a cable driven Mondeo clocks and then try out rev counter from them.
regards, Maciej
maciejd
Postby Mfr » Sun Jul 29, 2012 4:49 pm
Yeah thats it . I had to mix n match the parts to get it all to work right. If you look at the circuit on the back of the rev counter it is slightly different from on model to the next, can't remember what ones what now. I was lucky and had about 4 Mondeos to take bits off.
Mfr
Postby ediesbra » Tue Feb 05, 2013 3:57 am
Hiya everyone!! I've just put a 94 rev counter out of a mk1 Mondeo into me petrol speedo head (electronic drive) rev counter n temp n speedo works great!! Fuel gauge wandered so bad everytime I put me foot on accelerator it would shoot up etc. so I took needle off transit fuel gauge and fitted it into the decal for the Mondeo clocks, brimmed the tank and stuck the needle back on the full. Have done 100 miles and its sitting just under full, when I go round corners it does wander a lot, I've heard about this pcb on the back of the transit clocks , will it fit into 98 electric speedo for the Mondeo, cheers in advance.
2009 Mk7 2.4TDCI Jumbo in Panther Black with air con, cruise control, auto headlamps, auto wipers and hill start assist.
Former -
1998 MK5 150LWB
2005 MK6 Welfare unit 115 350 LWB Hi Top
ediesbra
