IgorVigor wrote:yes, and I have the ideal place for an EGT probe.....where the EGR used to be (well the link pipe is still there for the moment....but it could be removed )
does anyone have an official safe EGT temperature for the transit Di?
I'd have thought it was around the 650*c mark....
dieselhead123 wrote:The engine in mine is a genuine turbo one, 85ps and has an 'over engine' intercooler from a Mitsubishi L200 fitted below the bonnet.
The engine is VERY under fueled, mostly at full boost as the non turbo Bosch pump that is fitted to it has no Manifold Pressure Compensator.
The plan is to complete the 'intake' modifications, larger turbo and front mount intercooler, then start further pump alterations.
The 'power' screw has been wound in as far as the pump internals will allow and there is NEVER any black smoke!
The first fuel modification will be the fitting of a Manifold Pressure Compensator, larger injectors and then a 12mm fuel head.
Having driven my turbo model I would recommend a retro-fit turbo to any of you with non turbo di's as a worthwhile performance upgrade.
robbie.cee wrote:bloody good thread this well done guys theres gonna be a new wave of old vans flying past people soon!
