changing water pump
changing water pump
Postby transittrev » Mon Feb 20, 2012 11:32 pm
hi guys is it easy to change a water pump on a mk5 transit can you help us please thanks trev
transittrev
Re: changing water pump
Postby robbie.cee » Tue Feb 21, 2012 12:23 am
you have to ideally remove front grill, rad and slam panel to get easier access.
piece of piss after that.
loosen n remove belts for alternator n powersteering pump
turn crank by hand to align flywheel holes, fit locking pin. should also be lined up now for camshaft pulley pin hole and fuel pump pin hole.
fit all locking pins, loosen cambelt tensioner, remove cambelt, remove water pump.
replace pump, belt and tensioner with new.
refit in reverse order
check tension of cam belt, remove pins, turn 2 full revolutions, re pin to check nothings moved/jumped, remove pins and re fit every thing else!
2 hours plus refill antifreeze
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby twin wheel camper » Tue Feb 21, 2012 5:45 pm
If its a di you don,t need to touch the cambelt :? Don,t no about a petrol transit
twin wheel camper
Postby IgorVigor » Tue Feb 21, 2012 6:03 pm
you don't need to remove the cambelt.......
but considering its an extra few minutes to replace it, its an opportune time to do it......
the belt isnt expensive, and if you want to replace the tensioner, its also not that expensive.....
also note, that Ford state that if the timing belt is removed...it NEEDS to be replaced.....
IgorVigor
Postby MOGGY 1 » Fri Feb 24, 2012 12:53 am
Thinking of changing cambelt and tensioner ready for summer ,Question : How many lock pins do you lock with and how do you come across them ? . 2.5 banana Mk5..Just recently got the van "Peggy"and am going to give it a service and change cam belt while i am on with it,Would appreciate advice thanks,Harold.
All my favourite memories are in the past.
MOGGY 1
Postby Aardvark » Fri Feb 24, 2012 11:15 am
There are some threads here that say you can use drill bits. Do a search here for the sizes.
Learning to love rust.........
Aardvark
Postby IgorVigor » Fri Feb 24, 2012 11:53 am
yes, drill bits work well :)
you need 3 to lock the required components:
8mm for the cam sprocket
6mm or 9mm for the injection pump (my bosch pump used the 9mm)
and its stated as a 13mm for the flywheel.
I personally had to use a 12mm as the 13mm wouldn't fit mine....
but its all timed up correctly, so I don't care :lol:
IgorVigor
Postby Altransit » Fri Feb 24, 2012 12:19 pm
I prefer the correct pins myself, they're a dead fit, and you can't pin up the flywheel in the wrong hole if you use these:-
DRAPER 52576 FORD DIESEL ENGINE TIMING KIT 7 PIECE
£ 20.50 - SOLD (fixed price)
Ended Fri May 23rd  4:36pm BST
Seller: marshallandparsonsltd
Postby derv23 » Fri Feb 24, 2012 12:54 pm
On the ebay link above the pins stated say they are for 1.6 & 1.8 engines. Can they be used ok for the 2.5? Or are different ones needed? As im sure you can tell im not clued up on pins :?
MK5 Tourneo.
derv23
Postby transit120mick » Fri Feb 24, 2012 2:04 pm
derv23 wrote:On the ebay link above the pins stated say they are for 1.6 & 1.8 engines. Can they be used ok for the 2.5? Or are different ones needed? As im sure you can tell im not clued up on pins :?
These state they are for the 2.5 Di. :)
FORD DIESEL ENGINE INJECTION TIMING KIT
£ 11.50 - SOLD (fixed price)
Ended Sat Jun 8th  1:09am BST
Seller: bid4toolsno1
Mick
transit120mick
Postby Altransit » Fri Feb 24, 2012 2:27 pm
Yes, It's the same kit anyway, I've used mine both on the 2.5Di, and my Focus 1.8TDDi 8) :D
Postby derv23 » Fri Feb 24, 2012 2:47 pm
Cheers guys. I was just curious as i am still to do my belts and tensioner,pump etc and i am still to get the pins so thought i'd better check :D
Ta muchly
MK5 Tourneo.
derv23
