none starter
none starter
Postby dave8syl » Fri Aug 17, 2012 9:08 am
hi, any ideas
1997 2.5td auto
been parked up a wk ,while waiting/putting in a radiator
batteries charged. checked cleaned connections
checked i havent pulled any wires loose
its not even trying to turn, get a click from around the alternator :( :x
? any 1 know whats the red symbol next to the oil can 1 is
am going to try and bypass the inibhitor switch later today
thanks inadvance
dave8syl
Re: none starter
Postby Altransit » Fri Aug 17, 2012 9:10 am
What is the PATS LED doing :?:
Re: none starter
Postby dave8syl » Fri Aug 17, 2012 9:31 am
hi, ya
its flashing quite fast when with ign on
dave8syl
Re: none starter
Postby Altransit » Fri Aug 17, 2012 9:35 am
You need to wait until it stops flashing fast, and then it will flash out a two digit code :wink:
Re: none starter
Postby dave8syl » Fri Aug 17, 2012 9:51 am
hi, al
had to turn key to starter pos & release
then it reset to just 1 flash every 2sec for 10 times
then goes out
dave8syl
Re: none starter
Postby vanfox » Fri Aug 17, 2012 10:36 am
Mine coughs occasionally. Take piece of wire, about 3 ft long, with a crimp on one end and bare the other. Disconnect the starter solenoid thin wire and connect the crimp.Touch the other end on the battery positive. The starter should turn the engine. If it don't there's a pointer to your problem. Sticking solenoid or worn, sticking brushes. If it does turn, start looking further up the chain.
vanfox
Re: none starter
Postby dave8syl » Fri Aug 17, 2012 8:13 pm
hi,
found the prob
i run alive to starter/sol and it turned over
messed about with inhibtor switch no luck
took shroud of steering col and found loose/worn imolblizer around key
glued it in place, starting as norm first turn of key
dave8syl
