Ice cream van engine problem
Re: Ice cream van engine problem
Postby ceurieusneus » Thu Jul 21, 2016 10:06 pm
Tone, this is an old topic, last post on it was sept 17 2012.
Warblington, who started the topic has only 6 treads, all written in this topic.
It is possible he never opens this forum again.
You could PM him, (private message).
You could start a new topic with your problem.
Normally, diesels are not build for idling.
Personally, if the smoke disappears after a while, I would not starting to work on it, but that's just my thoughts....
However, If the body of the van is sound, you could think it over, to buy a spare engine now, now that they are still available and reasonable cheap.
That's what I have done. :D
Writing was not invented to look for spelling errors :wink:
Ford Anglia '62, Mercedes 200 '86, Transit ambulance/camper '88, Mercedes CE300 '89, caravan Puck '75
My ambulance conversion
ceurieusneus
Postby Tone99 » Fri Jul 22, 2016 7:06 pm
Thanks. I've sent him a PM. Apart from smoke after being stationery the motor runs good. Mileage is 80k but add another 30% because it idles to run the ice cream machine. Body is v good no rust never driven on salted roads. I've got time to ponder, gonna be a winter job. Maybe take head off, check valves, if check oil rings then it's a new engine. I am worried about getting a engine with an unknown history, it must be reliable. A day off the road is can be expensive.
Tone99
Postby Keef » Fri Jul 22, 2016 7:15 pm
He hasn't logged on since Mon Sep 17, 2012 8:52 pm so he's unlikely to answer you :wink:
Keef
Postby walt1984 » Fri Jul 22, 2016 8:37 pm
If reliability is a must have you thought about getting a spare engine rebuilt, maybe a spare box and axle and a few spares like a starter, water pump etc. The youngest of these vans must be 15 year old.
Sent from my P330X using Tapatalk
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Postby vanfox » Sun Jul 24, 2016 9:27 am
For the benefit of us non-icecream vendors, what does the Di do all day, actually run the machine, charge the battery or what?
vanfox
Postby Tone99 » Sun Jul 24, 2016 10:12 am
Morning. On a van with a carpigiani machine or similar, there is belt driven take off from the engine. This turns all the machine parts, compressor, condenser fan, ice cream pump etc via a number of belt driven shafts. Power on/off is enabled by electric clutches. Is it also possible to fit a high output alternator for 3000w invertor to power the freezer or slush machine. So no engine on means no 99. Thanks
Tone99
Postby AndyG » Sun Jul 24, 2016 10:36 am
