gates cambelt kit width problem
Postby pedracer » Sat Mar 16, 2013 7:49 pm
http://www.ebay.co.uk/itm/230844164110? ... 1497.l2649
listed as 94-2000. But it's a 28mm belt. and it doesn't fit my 1996. Which is 25mm width. Arse. should be listed as 1997-2000.
pedracer
Re: gates cambelt kit width problem
Postby AndyG » Sat Mar 16, 2013 9:56 pm
You are quite right :!: :)
Postby Mr RVM » Sat Mar 16, 2013 10:47 pm
HOW MUCH :?: :?: :?: that guy with a di in his landrover got one delivered to somewhere in the states for about that, and he got it from jeff (jollygoodcarsspares) in newport through ebay :!: there,s loads on there for half that or less check out item number https://www.ebay.co.uk/itm/230766886386 dont know if its the right one for your 96 but its one of many that are a lot less than you paid, send yours back and search for a cheaper one
Mr RVM
Postby Altransit » Sat Mar 16, 2013 11:57 pm
That would be about the right price for a Gates kit :?
Postby pedracer » Sun Mar 17, 2013 12:49 am
any idea what the correct gates kit part number would be for the 25mm belt?
BTW, many thanks to the folk who have done the "howto" features on the transit engine.
pedracer
Postby Mr RVM » Sun Mar 17, 2013 3:19 am
As it happens the ebay item number i posted earlier seems to be the kit you require gates part number K015571XS and at 25 quid plus delivery is a more realistic price for a BRAND NEW GATES timing belt kit :!: :!: :!: some of you want to start looking in the right places for your bits you could save a fortune, there is a recession on you know :!: :lol: :lol: :lol:
Mr RVM
Postby BobNZ » Mon Feb 05, 2018 8:33 am
I have been hunting for a cam belt for my 1999 2.5TD.
In New Zealand prices can be over the top . :cry:
Ebay purchases take time to be delivered,
So far my quest has been to follow up on Gates belts and kits
To me it looks like the two widths are 25mm and 28mm approximately.
K015571ZS kit has a belt of 130 teeth and is approximately 25mm wide The matching belt alone is 5571XS
The later Transit Mk 5 takes a wider belt
K015572XS kt has a belt of 130 teeth and approximately 28mm wide. The matching belt alone is 5572XS.
It looks like the automatic tensioner in both kits is 32mm wide and 60mm in diameter. Gates Tensioner Pulley T43124
Could someone who is familiar confirm or correct that info please. :D :D
1999 Mk 5 190 Tdi EPIC
BobNZ
Postby Chug » Mon Feb 05, 2018 10:38 am
Chug
Postby MinorMatt » Mon Feb 05, 2018 4:49 pm
Tensioners are the same on both belt kits. You will need 28mm wide
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby cherniy_chack » Mon Feb 05, 2018 6:23 pm
MinorMatt wrote:Tensioners are the same on both belt kits. You will need 28mm wide
This is not true.
The width of the toothed pulley on the crankshaft Mk4 is less than 28 mm.
A wide belt simply does not lie on such a pulley.
To use a 28 mm wide belt, the crankshaft pulley block must be replaced.
cherniy_chack
Postby Altransit » Mon Feb 05, 2018 6:37 pm
This is not true.
You're quite right, but Matt said that the tensioners are the same, not the pulleys, and this is a Mk5 we're talking about here :|
Postby cherniy_chack » Tue Feb 06, 2018 6:45 pm
The author of the topic worries about the width of the belts, and the tensioning rollers of both types are used with any belt.
cherniy_chack
Postby Jim Archer » Tue Feb 06, 2018 8:11 pm
The original author posted in 2013, the question Matt is replying to was BobNZs posted in 2018.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby MinorMatt » Fri Feb 09, 2018 10:23 am
And who said anything about the crankshaft pulley????
The tensioners on 25mm and 28mm belts are the same. The crank pulleys are not... but you don't change the pulley when you change the belt!
93 L GL Minibus
