aftermarket alarm and central locking kits.
Postby dc1984 » Mon Apr 08, 2013 9:29 am
Hi folks.
I am thinking about buying one of those ebay universal kits for my beavertail mk5 but was wondering if anyone has had any experience with any of these kits?
Also am i best going to for for a new lock set?
Thanks,
David.
dc1984
Re: aftermarket alarm and central locking kits.
Postby ediesbra » Tue Apr 09, 2013 10:24 am
Hi mate I have a hawk alarm fitted to mine and a hawk central locking kit waiting to go on, seems to work well. Cheers
2009 Mk7 2.4TDCI Jumbo in Panther Black with air con, cruise control, auto headlamps, auto wipers and hill start assist.
Former -
1998 MK5 150LWB
2005 MK6 Welfare unit 115 350 LWB Hi Top
ediesbra
Postby dc1984 » Tue Apr 09, 2013 12:53 pm
Thanks mate. Where did you get it from and do you have a rough idea how much they are?
Thanks,
David.
dc1984
Postby ediesbra » Sat Apr 13, 2013 8:20 am
I think I paid around £50 but can't remember off top of my head, I bought it direct from hawk alarms. Easy enough to wire up and does the job :) just gotta get round to sorting the central locking part lol.
Former -
1998 MK5 150LWB
ediesbra
Postby dc1984 » Sat Apr 13, 2013 9:29 am
Cheers mate. I will look them up today.
Its not good when any ford key opens the van:(
dc1984
Postby ediesbra » Sat Apr 13, 2013 8:00 pm
Lol Deffo not mate, there's a guide on here for the central locking figment, ill grab me laptop and find the link in a while. Cheers
Former -
1998 MK5 150LWB
ediesbra
Postby evilgoat » Sat Apr 13, 2013 8:23 pm
ediesbra wrote:Lol Deffo not mate, there's a guide on here for the central locking figment, ill grab me laptop and find the link in a while. Cheers
Last few installs I have done have been Scorpion with OEM CL kits. Not had a problem with them ever.
evilgoat
Postby dc1984 » Sat Apr 13, 2013 11:35 pm
Cheers lads,
I randomly found a new, still boxed Falcon Preditor Evo 3 alarm for £40 on gumtree and it's only 2 miles from my front door :D
I think I will ask my local Ford dealer for a price for central locking and a new lock set.
I found aftermarket lock sets on eBay but I'm not sure if my key has a chip in it, is there any way to find out? It's just a basic Key I have without any buttons.
Thanks,
David.
dc1984
Postby ediesbra » Sun Apr 14, 2013 6:01 pm
Regardless of the chip mate you'll be fine, the chip is just for immobiliser I believe.
Former -
1998 MK5 150LWB
ediesbra
Postby dc1984 » Sun Apr 14, 2013 7:57 pm
Superb mate, thanks for that :D
David.
dc1984
Postby Rickbu » Sun Apr 21, 2013 9:37 am
Just buy a universal central locking kit, about 12 quid on eBay and easy to fit . Lock sets too are cheap on there. There are guides on here as to fitting the lock motors
1998 county X2 one daily use one waiting restoration
2000 mk5 self build motorhome restored and built
1995 Isuzu trooper 3.1 td
2000 astra 1.7 td Isuzu power conversation
Rickbu
Postby evilgoat » Sat May 11, 2013 10:49 am
About to fit one today. Will get pics
evilgoat
Postby evilgoat » Sat May 11, 2013 4:09 pm
Ok, word of advice to those fitting a standard aftermarket CL kit to a mk5 - DONT!
All morning and most of this afternoon has been spent on this and I have ONE door on the system and now been rained off. Any pretnce of doing a howto has gone too.
Door card off and your first problem is the metal security sheild round the lock. No problem as 4 rivets to drill out and its all exposed. Then theres the bloody plastic cover to do battle with. now....
EVERY car I've done the lock rod is free to move at all times, meaning if the key is in or out of the lock the rod cam move. Mornally its a centre sprung affair and the lock barrel simply moved a cam or similar leaving the rod free to move. Not so here. The rod is free to move ONLY to the lock position, it will not move to the unlock position less the key is in. This means you cant attach to the lock rod. The cable mech used for the door handle precludes the use of that so you are left with one choice. Disable the key lock in the door and drive the lock rod directly from the servo. My lock is nadgered and thats why I'm doing this, so no biggie there.
Next issue is the two normal servos you get dont quite have enough throw AND they move in the wrong direction, eg, up unlocks, where on the Transit, up locks. Simply flip the servo wires AND the master switch wires, else the module will command unlock, see the servo move to lock, and try and command a lock again and so on. The throw issue, with careful adjusting you can get it to sit in just the right place to lock and unlock. Everything is threadlocked because I can see it moving otherwise.
No, PAS door is going to be the same, which will also mean loosing the keylock in the door. I'm guessing back and side doors wont, so as long as I have a door the keys can open I'm happy disconnecting both front locks. I have no bulkhead so leaning over the seat isnt an issue.
I'd suggest the BEST route would actually be to fit the Ford lock mechs with the servo from a CL van/car.
evilgoat
Postby Rickbu » Sat May 11, 2013 11:16 pm
You actually did it wrong, you don't attach to the lock barrel rod you need to drill a hole into one of the levers on the door lock unit itself to enable you to attach a rod For the solenoid. It's been covered on Here already, I have already fitted one of these kits to my mk5 with remote central locking including the sliding door and you can still use the keys
Rickbu
Postby Rickbu » Sat May 11, 2013 11:23 pm
If you take the lock unit put of the door and lock and unlock the door with the handle you will see a little lever being flicked back and forth, that's the one you drill into to attach a rod to I can't remember what the title of the post on here that details all this with pictures
Rickbu
