epic fly by wire pump ....
Postby chth1812 » Sat Apr 20, 2013 9:35 am
Hello,
Can somebody let me know which is the appropriate (original) Lucas pump type for a 1995 2.5Td 85HP Transit? I bought the car last year but it has problems in accelerating and switching off. Could this be related to connection between the ECU and the pump?
chth1812
Re: epic fly by wire pump
Postby AndyG » Sat Apr 20, 2013 11:51 pm
chth1812 wrote:Hello,
Sounds like the ESOS plunger has gone :!: (Electronic Switch Off Solenoid)
The pump has to take alternative action to switch the engine off and you will have reduced power when switched on :!:
If you want full power, remember to stall the engine as you switch it off to fool the ECU into thinking the ESOS is working :idea:
In the meantime, search ESOS on the forum and find the how to change it :)
Re: epic fly by wire pump ....
Postby chth1812 » Sun Apr 21, 2013 10:53 pm
Thanks a lot Andy. However I tried to find this Delphi repair kit but it's rather impossible, at least on internet. Do you have any idea where I might order it from? Finland is not the easiest place to find such parts in the market, so if you have any suggestions about ordering through internet I'd highly appreciate it.
chth1812
Postby Altransit » Sun Apr 21, 2013 10:55 pm
:idea: Try a PM to dieselhead123, he may be able to help :wink:
:arrow: memberlist.php?mode=viewprofile&u=42705
Postby dieselhead123 » Sun Apr 21, 2013 11:07 pm
Hi there, yes, we should be able to help with the supply of the pump parts you need.
Our Delphi wholesaler has sent part to members in many counties on our behalf, so Finland won't be a problem.
To start off, we will need the full numbers and codes from your pump, DSA???????? etc.
Once you carry out the 'test' mentioned by AndyG to confirm that the ESOS unit is at fault, we will happily provide you with a pricing including insured delivery for the parts you need.
Hope this helps,
Postby chth1812 » Mon May 13, 2013 9:25 am
Thanks a lot, dieselhead123!
Well, I did what AndyG suggested and I regained full power. It seems that the car is working fine now except from the switching-off problem, so probably I need to do something with the ESOS.
The pump identification is the following:DSA1096, 07782, Mod MMG, Ser 8720A010A
Looking forward to hearing from you about prices and delivery time.
Thanks again,
Chris
chth1812
