Manual shifting A4LD
Postby Kedishen » Sun May 12, 2013 11:33 pm
Hi guys
I been hitting a lot of hills lately and been manually shifting to 2nd and 1st to keep the revs.
when running down hill, I am using 2nd to help control the speed.
will doing this damage the autobox? I always reduce speed with brakes to suit gear before shifting.
Also, I'd like to be able to get the box to drop into overdrive, 4th gear, 1:1 without having to have pedal just right. can this be done?
I can rarely get it into 4th below 35mph, so driving around revving all the time when I would rather not be.
Thanks.
Scott
Livin' in me van in Portugal.
'93 Mk4 TD 150L Hitop Custom Camper
100ps Epic blue spot
Kedishen
Re: Manual shifting A4LD
Postby Kedishen » Tue May 14, 2013 10:59 pm
Some interesting reading on the subject
Understanding The A4ld Converter Clutch Lock Up
http://www.bobcat.ca/stuff/DOCS/A4LDDU~2.PDF
ATSG Service Manual
http://sierraautomatico.files.wordpress ... alatsg.pdf
Fitting manual lockup switch
http://www.therangerstation.com/forums/ ... hp?t=85795
Kedishen
Postby AndyG » Wed May 15, 2013 1:21 am
The transmission fitted to the smiley Transit is an A4lde and does not contain any internal electronic solenoids :!:
And what rpm do you think your engine is doing at 35mph in overdrive 4th :?:
Postby AlanN » Wed May 15, 2013 7:58 am
Isnt 3rd already 1:1, so overdrive would be like trying to go in to 5th+ gear
Postby Kedishen » Wed May 15, 2013 10:05 am
AndyG wrote:The transmission fitted to the smiley Transit is an A4lde and does not contain any internal electronic solenoids :!:
Van is a late mk4
I been reading a lot about people cutting into a ground wire to the lockup solenoid on side on box and using a switch to reproduce the lockup signal. this will not work on the transit box?
I was just rereading through one of your old posts and you refer to a pressure solenoid. name suggests no wires involved. so transit box is completely vacuum based?
Tbh m8 I couldn't tell you what the revs would be.
when the shift occurs depends on how I been driving.
I never leave it in D when getting up to speed. I shift all gears manually. to get it to 2nd I have be going at least 15mph. to get to 3rd I have to go at least 29mph and have the accelator just so. if I change before then, it changes to intermediary gears which are abit like the next gear, but just rev but provide no pulling power.
it locks up in third ok and will change to overdrive at about 35/36mph with the right pedal position (otherwise its the intermediary revving gear, specially on hills)
VERY rarely, I can get it into overdrive at 31 and keep it there. this only happens if I been soft pedalling for a while and requires some very fine throttle work.
when going uphill, once I drop below 45, box wants to change down. I can stop this by reducing throttle to keep overdrive locked up but once I hit about 36 I can't stop it.
when it does change, it won't go to third, it goes to the intermediary gear that just keeps the revs up but doesn't pull. this is why I shift to 3rd. same situation applies to 2nd and 1st with these intermediary gears so I change manually.
recentl when i am soft pedalling around town, I drive as if i have a clutch and when i shift, i take foot off accelator. this produces a good change at low speed for 1st-2nd-3rd with no intermediary gear.
I am guessing these intermediary gears is the box slipping?
when changing to reverse and i am impatient, it thinks about the change, but only when I have litterally jammed it in there cuz i am doing a 3point turn in a traffic jam or summit. Also kickdown doesn't work. No other issues.
Oil is still a nice cherry red (my overheating problems are a thing of the past).
Kedishen
Postby AndyG » Wed May 15, 2013 11:35 am
Is this the camper that was converted from an 80PS N/A to a turbo intercooled with Bosch pump :?:
Postby Kedishen » Wed May 15, 2013 11:50 am
Sure is. You must have filing cabinet with it all in :)
Kedishen
