I have F reg MK3 recovery truck with a pinto engine.
Starting the truck became difficult over winter so i assumed it was cold start issues due to the cold winter we have just experienced.
It wont start normally. However, if I feed petrol into the carburetor petrol reserve through carburetor fuel inlet but will start and run happily only for a short while , i assume until that runs out. So I have ruled out an engine /spark /carburetor issue.
I have the tank full of petrol. I have tried sucking the fuel line before carburetor and observed that i wont get a steady flow of fuel.
I have also taken the fuel line before the fuel pump and tried sucking, still no steady fuel flow as above. So I am tempted to think that it may be a blocked petrol filter.
So my question is where would the fuel filter in a pinto truck be located, as I have followed the fuel lines all the way to the tank with no filter in sight.
I have tried googling as to whether there would be an in-tank petrol filter with no conclusive results.
Any help/suggestions will be mostly appreciated
