MKuser wrote:I'm getting overheating problem again...I've changed the water pump ,it's now 3 years,and everything ok but ,the other day ,I went up some mountain roads and the temperature went high,not on the red .After that,the temperature is always higher as normal and goes up when I take another inclinated road.Could I fix it with a reparation liquid in the coolant system?If I have to change the head gasket,does anybody know a tutorial to do it myself?Thanks.
gotgcoalman wrote:head gasket is normally good for 250,000 miles or 400,000 km .
so it's not a regular thing
unless you've had major overheating issues.
do the radiator pipes become hard? (top rubber hose)
is there excessive pressure in the expansion tank?
did you recently drain the cooling system and re fill (could be an air lock)
how much water/coolant are you loosing?
how much white smoke when driving? (coolant in cylinders = lots)
