Benefits of fitting turbo
Postby bobdragon12 » Thu Dec 05, 2013 8:48 pm
Are there good benifits to fitting a stock turbo to a non DI and do the injectors need changing ?
MK2 LHD coachbuilt Camper 2.5TDI
bobdragon12
Re: Benefits of fitting turbo
Postby F111ORY » Thu Dec 05, 2013 9:15 pm
Hi, The benefit is great. I have done it to two engines and are just about to do it to a third. I have not changed the injectors and have turned up the fuel about 3/4 of a turn. You get more torque and the engine does not run out of go in the higher rev band.
Definitely recommended.
F111ORY
Postby bobdragon12 » Thu Dec 05, 2013 9:26 pm
Good stuff , just found a complete one in my local scrapy so will strip it down tomorrow
bobdragon12
Postby F111ORY » Thu Dec 05, 2013 9:52 pm
I'm told that changing the injectors for turbo ones is better , but have not got that far myself yet.
F111ORY
Postby bobdragon12 » Thu Dec 05, 2013 9:53 pm
Will probably take them if there still there which I think they are
bobdragon12
Postby bobdragon12 » Fri Dec 06, 2013 2:49 pm
Well got the inlet and outlet plus turbo off today at scrappy , £40 seemed good to me . Just need to go pickup the sump and down pipe tomorrow morning :D
bobdragon12
Postby F111ORY » Fri Dec 06, 2013 8:36 pm
Hi, Save yourself a load of agro. Just weld a 20mm hydraulic fitting to your existing sump!
Use the turbo and down pipe to position it.
F111ORY
Postby bobdragon12 » Sat Dec 07, 2013 5:32 pm
Yeh gave up trying to get it off so will fit something to the sump . I have yet to look but is there a oil feed in the same location under the manifold on a non turbo ?
bobdragon12
Postby nick217 » Sat Dec 07, 2013 7:18 pm
I would have removed the engine as one complete unit then strip it off at your own pleasure.
nick217
Postby F111ORY » Sat Dec 07, 2013 7:54 pm
Hi, There is a oil feed on non turbo engines after 1992, if you can get the plug out!
F111ORY
Postby bobdragon12 » Sat Dec 07, 2013 8:09 pm
Cheers , will take the exhaust of and have a look , if not I assume I will have to tee off the alternator ?
bobdragon12
Postby F111ORY » Sat Dec 07, 2013 10:05 pm
Hi, Its only a small tapping and I don't know just how much the alternator uses, it may not be able to feed both. I have always teed off the oil pressure switch as that does not use any oil !
F111ORY
Postby MinorMatt » Sun Dec 08, 2013 2:55 pm
Yeah there is a plug on the oil gallery under the exhaust manifold for the turbo. They are bleeding tight, sometimes they come out, sometimes they need "persuasion" - I normally weld something to the plug and use that to get the plug out...
People have successfully Tee'd of the alternator feed.
Turbo injectors do make a big difference
Postby bobdragon12 » Sun Dec 08, 2013 5:00 pm
Well had a go at getting the oils feeds unplugged , got the smaller one out ok but the larger one I admit I may of beat a little hard , whats the lowest one for ? does anyone know the 2 threads sizes used as I need to order a new feed pipe
bobdragon12
Postby dieselhead123 » Sun Dec 08, 2013 6:19 pm
The top one is the one you want out mate.
