Engine Code Location?
Postby Lsecouriers » Thu Dec 19, 2013 10:06 am
After a right nightmare with my 2.5 di turbo not starting ive just bought a whole new ex rac engine from eBay in good running order, going to have a mechanic drop it in tomorrow but before hand i want to get a service kit cambelt etc, obviously its not the exact same engine that was in mine so does anyone know if i can find the engine code out if so where too
cheers
Lsecouriers
Re: Engine Code Location?
Postby MinorMatt » Thu Dec 19, 2013 10:37 am
Behind the power steering pump.
But it won't run right without the correct lucas pump - will be on limp home mode. You need to make sure the DSA **** number on the pumps match - or put the old one on.
Lucas Laser 2000 & IDS
93 L GL Minibus
96 P 150 TD 100PS LWB Hi-Top
Postby Lsecouriers » Thu Dec 19, 2013 11:22 am
The guy i have bought the engine from included everything the pump the lot. will it be ok?
Lsecouriers
Postby MinorMatt » Thu Dec 19, 2013 11:36 am
depends if the pump is the same as yours or not...
93 L GL Minibus
Postby vanfox » Thu Dec 19, 2013 11:43 am
A service is easy to do once it's installed. I'd get the engine installed and running before pulling it (an unknown engine) to pieces.
You don't say if it's a turbo or an N/A Di? Epic or Bosch pump?
vanfox
Postby Lsecouriers » Thu Dec 19, 2013 11:53 am
It's a turbo unsure what pump I'm just waiting on it to arrive all I know is its fly by wire which Is the same as mine
Lsecouriers
Postby MinorMatt » Thu Dec 19, 2013 11:59 am
So they are both Lucas, and for it to work correctly you need to a) make sure the DSA**** numbers are the same, and if not swap injection pumps and injectors.
93 L GL Minibus
Postby Lsecouriers » Thu Dec 19, 2013 11:16 pm
Right my pump in my van is DSA1191
Where the other engine with all injectors etc and pump is DSA1190
How can we make this work, with a bit of looking about i see the DSA1190 is running 100PS, where my current sezied engine pump is only running 85.
if like the 100PS to be fair as carry alot of weight and need some power.
if anyone can advise me would be great
Lsecouriers
Postby AndyG » Fri Dec 20, 2013 12:56 am
Lsecouriers wrote:Right my pump in my van is DSA1191
I think you may have your pump and outputs back to front :idea:
Simply fit your old pump to the "new" engine :!:
Postby Lsecouriers » Fri Dec 20, 2013 2:07 am
injectors too?
The new engine has the 100PS bump where my current engine that is seized has the 85PS pump.
i want to run 100Ps so what else would i need just the ecu from the other vehicle?
regards
Lsecouriers
Postby AndyG » Fri Dec 20, 2013 2:13 am
If the "new" engine is the 100PS, (and you'd like a proper 100PS in your van) you'll need to also transfer the ECU, PATS module and the chip from the "new" engine/van's key into your existing key :idea:
Postby Lsecouriers » Fri Dec 20, 2013 3:02 am
Alot of hassle I take it then?
Lsecouriers
Postby Jim Archer » Fri Dec 20, 2013 9:39 am
Thought all the RAC vans were 85ps?
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby Lsecouriers » Fri Dec 20, 2013 9:49 am
Unsure I'm only saying what I've been told
Lsecouriers
Postby Jim Archer » Fri Dec 20, 2013 2:50 pm
Easy way is just swap your pump on to the new lump. Only issue I can think of is the ECU might get the hump if it's not happy with the other injectors - in which case swap them over.
Jim
Jim Archer
